Old 05-09-2006   #11
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
Re: Interesting engine problem
Just went out to work on the car a bit and I started it up and now it wont even idle when cold. So I ran it for a bit while holding the gas down slightly. A few things I noticed through the pocketlogger:
When the car was not running, I was seeing a slight airflow (.16 lb/min) not sure if this means anything
After the car was almost warmed up, the idle was fluctuating about 50 rpm, which was noticible
The coolent temperature sensor and TPS were all giving normal readings
tsiawdspeed is offline   Reply With Quote
