Old 05-25-2006   #4
x-pride
x-pride's Avatar
Re: Wanna swap my 7bolt 4G63T into a Colt
Originally Posted by 98GSX
The motor is the current on in my GSX and i wanna swap it into my 93 Dodge Colt to make the ultimate 4 door sleeper... My questions are these what is need to do the swap??? From my understanding and the little research I did I just have to modifiy the right main motor mount ( if your facing the motor) other than that its just a direct swap??? Can I use the the wireharnesses and just run the current ecu that came with the motor? Is supsention in the front gonna be an issue? Can I use the cv shafts from a GST? Ialso need a tranny or will the AWD tranny work that I just had rebuilt? Let me know what ya think or a forum, if there is one that I could float around in a find out some more information. Thanks in advance
Nick
I hope you have money. This swap is expensive. We did a swap in a 89 colt GT and it ran us close to 4k not including the car.
To answer some of your question. You will need a harness from a turbo car I don't know if it has to be a 1990 like 89 colts. You will need an ecu from a turbo car because you need the fuel map. I believe you can use the 5 speed tranny from a colt but you need to change the flywheel to an FWD fly wheel off an turbo car. As the motor goes you want to use a 1G motor and not a 2g motor. Has to do with the way it mounts. Go to 4g61t and they can answer all your questions. Wish you the best of luck. The best way to do this swap is to buy a car that already have the swap done.
Nick also check with PJ he has the colt with the swap.
