Old 06-25-2006   #2
Re: Oil light question.
check the wires to the sensor. Also, you sure your oil is good? not leaking from the turbo, or anything? it's cause of low oil pressure, but with 10w30, that should still be good, assuming there is no issue. do you have an aftermarket oil psi gauge? i'd check that wiring, or maybe the sensor is bad.
-A. Swift
