Old 07-14-2006   #7
Re: Grilling / BBQ Styles, Tips, and Tricks.
Originally Posted by unreal808
I’m lazy I use propane.
But I should get a charcoal grill for when I have the time. The advice from Matt is solid, especially the lighter fluid part.
I keep thinking of things every time I read this thread...
The best and easiest way to light the charcoal using paper is to get a chimney from the hardware store or pretty much any place that sells charcoal grills. It's basically a can about the size of a coffee can but a little taller, with a grate on the bottom to elevate the charcoal and allow air in underneath it. You put paper in first, then charcoal on top, light the paper and in 5-10 minutes you will have glowing hot charcoal. You can also make your own chimney out of a coffee can or any other sort of metal pipe, just make sure it can get air from the bottom and that there's a way to light the paper.
