Go Back   MitsuStyle > Tech > The Good Stuff
Old 01-26-2004   #3
ACRucrazy
12V|white/red |+ |ignition harness |
| STARTER|black/red |+ |ignition harness |
| IGNITION|dk. green |+ |ignition harness |
| ACCESSORY|blue/red |+ |ignition harness |
| SECOND ACCESSORY|blue/black |+ |ignition harness |
| POWER LOCK|lt. green/black *2 |- |drivers kick panel *1 |
| POWER UNLOCK|orange *2 |- |drivers kick panel *1 |
| LOCK MOTOR|lt. green | |drivers kick panel *1 |
| UNLOCK MOTOR|dk. green/red | |drivers kick panel *1 |
| DISARM DEFEAT|blue/black | |passenger kick panel or *9 |
| PARKING LIGHTS +|grn/wht or pnk/blk | |low in drivers kick |
| HEADLIGHTS|orange |- |headlight relay under hood |
| DOOR TRIGGER|green/yellow |- |fuse box *8 |
| DOME SUPERVISION|green/orange |- |fuse box *3 |
| TRUNK/HATCH PIN|red |- |drivers kick panel *7 |
|TRNK/HTCH RELEASE|green/white |5wi|drivers kick panel *7 |
| FCTRY ALARM ARM|arms with lock | | |
|FCTRY ALRM DISARM|disarms with unlock | | |
| DISARM NO UNLOCK|*6 | | |
| TACHOMETER|*4 | |*4 |
| SPEED SENSE|white/blue | |center console *5 |
| BRAKE WIRE|green/orange |+ |brake pedal switch |
| HORN TRIGGER|lt. green/black |- |steering column |
| WIPERS|blu/org & blu/yel |+ |wiper motor |
| LF WINDOW UP/DN|red/blk - grn/blk |A |drivers window switch |
| RF WINDOW UP/DN|red/wht - green |A |drivers kick panel *1 |
| SUN RF OPN/CLOSE|not recommended | | |
| RADIO 12V|orange/black |+ |radio |
| RADIO SWITCH|white/black |+ |radio |
| RADIO ILLUMINATE|green/white |+ |radio |
| LF SPEAKER|wht/blu - blk/blu | |radio |
| RF SPEAKER|wht/red - blk/red | |radio |
| LR SPEAKER|yel/blu - gry/blu | |radio |
| RR SPEAKER|yel/red - gry/red | |radio |
Notes:
NOTE: This vehicle is equipped with an immobilizer. Use DEI part number 555U to bypass during remote start operation. *1 Located in a black 32 pin plug. *2 These are the door key cylinder wires. Meter the wires while turning the key in the drivers door. Unlock requires a double pulse. On vehicles without the factory alarm use purple for lock and lt. green/red for unlock, these are the door lock switch wires. *3 In the plug on the upper right side of the fuse box under the driver side dash. *4 Go to the test connector inside the fusebox under the hood, it is a T shaped plug. Tach is the terminal on the top left of the T, the wire under the terminal is white or white/red. *5 Located in a large white 38 pin plug behind the radio. *6 To disarm without unlocking, use a single pulse on the unlock wire. *7 Located in a white 43 pin plug. *8 Located in a black 19 pin plug on the back of the fuse box under the driver side dash. *9 Also found in a black 20 pin plug on the front of the fuse box under the driver side dash.
Slow stuff
