Old 09-01-2006   #1
Re: Magnus/power products thr body?
Most TPS sensors are 0-5v units, but exactly what range they use in there is often very different from one kind of car to another. The TPS sensors on DSMs are adjustable and should be recalibrated whenever touched. The stock ECU uses the throttle position to help tell it when to go into idle mode and when to go from closed loop to open loop fueling.
