09-04-2006
#1
How to make a Quick 14B Car?
Anyone wanna just quick slap a list of some stuff I'd need to maybe run low 13's on a 14B (Just things to add power). Could I get to that goal with..., 3" exhaust, 1G ported cast exhaust parts, stock sidemount, race gas, boost controller, fuel pump?
Oh yeah It's a 92 awd 5 spd 6/4LSD w/ buschur 3"dp,tp,cb, shep stage 3, 2600w/6puck
#2
Sten Sniper
Drives: Evo VIII RS
Re: How to make a Quick 14B Car?
+SAFC, dyno time, C16, seat time.
09-04-2006
#3
You could hit a low 13 with that no problem. I ran a 13.6 with boost controller, pump gas, 2.5" hacked cat-back and ghetto UICP. Full weight on snow tires.
SAFC and UICP should get you well into the 12's.
09-04-2006
#4
Drives: the girls crazy
Just make sure you have the fuel to backup the boost
pics or gtfo
09-04-2006
#5
Crash Course Racing
Drives: in circles
I ran 12.99 @ 103 on my old AWD with an open downpipe, UICP, and some c16.
If you had safc 550's and a pump you could run that or better and not worry about blowing up.
09-04-2006
#6
Yea, go for it! Exhaust, fuel pump, 550's, and an afc. 2G mas for good measure, crank up the boost to about 25, drop the tire pressure in the front to about 17psi, and maybe about 13-15psi in the rear, and then get some good clean launches. Shit, you could run high 12's on that setup if you can drive well enough!
09-04-2006
#7
My girlfriend wents high 12s many times and 108mph with the 14B, air filter, 2.5" turboback exhaust, mbc, fuel pump, a homemade upper i/c pipe that didn't seem to help and race gas. Cher went something like 12.6 with similar basic mods. Someone else on here went low 12s with the 14B.
A 2G MAS, 550s, SAFC, FMIC, etc would be nice for tuning it.
09-04-2006
#8
Are you guys serious? Wow, if this is true then maybe i should think about keeping my B16G with pretty much the above mods, plus dsmlink, but minus the FMIC/pipes (i am stock IC system right now).
Sleepy good to hear that you are getting back in the game!!
09-04-2006
#9
13.4@98mph.
1.70x 60' 3bolt FTW!!  .
Mods:
s-afc, 3" 02 back exhaust, 2g mas in a 1g airbox setup, homebrewed intake pipe, aeromotive fpr, act 2600, walbro 255hp. Stock injectors, motor, etc... This was back in 2003?
Another mod, 90psi compression in cylinder #1, 135+ on the other 3.
15psi, 92 octane. Full weight.
Once I broke the 3 bolt the next pass at the track, I tossed in a 4 bolt and turned up the boost to 18psi, much faster.
I think nash then took this car put on his fmic, 660's, heads w/cams and 20g and went 11.6?
It really isn't that hard to get a strong 14b car into the low 13's, high 12's.
09-04-2006
#10
At-Least-It's-White-Again
Kevin, make it light. I guarantee if a 14b on race gas/stock motor was put into my white car it would go high 11s easy at about 113-114 no problem.
'04 Honda Ricer: stock
09-05-2006
#11
Alright, so I need to at least get a pump (duh). I'll probably buy a FMIC, but I need to wait until I get my bill from Shep haha.
#12
Dang kevin, my car is pretty much crap then! I'll probably drop by this weekend if your not doing anything!
09-05-2006
#13
Can't you get a MAF-T setup to do something similar to what a s-afc does?
09-05-2006
#14
I had similar mods, fuel pump for sure, and ran a bunch of 13.4 passes full weight and full exaust.
09-05-2006
#15
I have a MAFT actually, and a 91 EPROM. just get some injectors, and maybe get a RACE GAS chip burnt? And then just run 15ish psi on pump? Eh maybe I should just get DSMLink. Can someone tell me if you can save different "maps" on DSMLink?
#16
I'm thinking boost creep is gonna be EL GAY, I'm kinda in the market for an external gate o2 housing, but I can't find any.
#17
Just get the turbo ported. Much easier and cheaper.
09-06-2006
#18
Or bolt on a o2 housing, problem solved.
09-06-2006
#19
i have a mitsu flanged tubular 02 housing with a tial 40mm on it. interested?
#20
Yes
| Thread Tools |
| Display Modes |
Linear Mode
