Old 09-16-2006   #13
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: AWD tire wear
Originally Posted by S2kracka
It shouldn't, you are working harder, but the tires are moving just the same.
I think having no PS might reduce front tire life slightly. You crank the wheel alot w/out power steering if you're in a tight spot (while not moving which is not the way a tire was designed to turn! Lots of friction). Not like a power steering car where you can just turn the wheel as needed. You might be right though.
- Josh L.P.
