Old 09-21-2006   #3
Re: Boost fade
A T28 is more than capable of holding 18psi to 7000 RPM. Do you have a major restriction on your intake track? Really dirty air filter? Stock IC piping? Stock BOV? When doing the boost-leak test, how high have you tested it to?
BTW, unless you have a FMIC on your car you should not be running that much boost on pump gas, especially untuned. Do you have the fuel to support it (pump, injectors, etc.)?
