Old 09-25-2006   #7
Re: Water Injection
Almost everyone uses methanol injection nowdays(except for some ass backwards 3s guys who still use water injection or propane injection and some supercharged BMW guys that I have come across that still use water). Water injection is old school and I haven't seen better than mediocre results on the dyno with water only injection. You can use a water mix with meth injection. Meth add fuels to your setup, so you can run smaller injectors/fuel pump setup. Meth is high octane and cools the intake charge like nothing else. Cars that run meth as their primary fuel don't even need intercoolers.
You should be able to control any electronic injection system with the AEM EMS. If you have a way to check for sufficient methanol pressure/flow, you can setup the AEM EMS to reduce boost(with a simple solenoid or with AEM EMS boost control) or set it up to add fuel and reduce timing advance.
