Old 09-27-2006   #3
Re: Motor mounts
Like he said, do just the front and rear. I had all 4 which was definitely not good for a daily-driver. The front and rear alone will stiffen things up enough to really improve your shifting, and the remaining side rubbers mounts should take the edge off for normal driving. These are a real pain in the ass to install though, the mounts will need to be removed from the car and you'll either have to burn the old mounts out with or torch or use a press to get them out/in.
the ones I had were full mounts all the way around, no inserts.
