Old 09-28-2006   #4
tnm27
I'm the short one.
tnm27's Avatar
Re: Starter problems
when you try to start it, do the lights start to flash on and off? if so than i've had the same problem. i would first check the ecu cause mine got fried after that and i had to replace it. but eventually the problem came back after i relieved the fuel pressure system. you should turn the key on but don't try to ignite it and than push the window botton. just try, cause thats what i did to get my car to start.i thought it was the starter as well but when i took it to test at auto zone, it passed.
tnm27 is offline   Reply With Quote
