Old 10-08-2006   #6
acidrumz
Send a message via AIM to acidrumz
Re: Crank removal Q's
remove the front oil case, the oil pickup filter (remove that first then front case), the rear oil seal, flywheel and the main brackets. that one should have 8 bolts. pry the main brackets to remove them. notice the arrow on the brackets that points to the timing belt side of the engine for reinstallation.
goodluck.
acidrumz is offline   Reply With Quote
