Old 10-18-2006   #12
Re: 2-step
Originally Posted by Pushit2.0
Wire it off the clutch pedal switch, then when the cluch is pressed you have the 2step engaged.
The reason I don't like that is I like the clutch part way up so it is sitting just before engagement, so it would be off the switch.
I am in the same boat. The VSS isn't broken, but they haven't figured out how to get the VSS to work with the AEM (correct me if they figured it out). I am using the top switch on the clutch, but it is too picky. Breathe on it and it will go into 2 step, which I rest my foot on the clutch too often at the track.
I was going to install a custom switch on the clutch pedal, but if someone comes up with a better idea I am all for it!
