Old 10-19-2006   #10
Re: Fuel pump not turning on with ignition
If it works while the car is running, it's not the fuel pump.
You swapped out the large MPI relay under the stereo, right? Check the wiring to the MPI relay and see if you're getting a signal from the ignition. You might have a bad wire between the two or a bad ignition switch.
