Old 10-21-2006   #2
Re: Exhaust Housings: Garrett vs. FP vs. Mitsu
Originally Posted by sleepydsm
Is the difference in the Garret T3, the FP bolt on housing, and the Mitsu exhaust housing really that significant?
YES.
T3/T4 exhaust housings are your better choices due to the availability of different flow rates. This helps tune the turbo's spool rate and maximum HP potential to the engine/car.
The FP housing is well matched to the "optimum" flow a/r as determined by FP, whether it's correct or not as compared to the available T3/T4 housings is hard to say. Supposedly it falls in between the T3 .63 & T3 .82 housings. But the FP3053, FP3065 & FP3575 turbos seem to do really well.
It seems as if any other turbo with a Mitsu style housing is going to spool quicker, but have less HP potential due to the more restrictive exhaust flow.
Just remember lower a/r numbers = quicker spool-up with less HP potential and larger a/r numbers = slower spool-up with more HP potential.
Hope that helps.
