Old 10-25-2006   #4
tim
tim's Avatar
Re: packing the oil pump gears.
the front case came with all the seals already installed. so i probably dont need to rtv anything.
This is what I was refering to.
Kit installation...
This step assumes you have the timing belt off. Remove front balance shaft "B" belt, balance belt tensioner, and sprocket from the balance shaft (the sprocket is still in place in this picture). The hole for the balance belt tensioner is circled. When reinstalling the oilpump cover, make sure to either get a new shorter bolt, or install the old pulley and bolt. Put some RTV on the bolt threads before tightening it down. If you do not seal this hole, you will have a massive oil leak.
