Old 10-27-2006   #26
Re: BOV Flutter
It is a brand new one, and just to re-iterate this does not happen under WOT, it happens at part throttle and it is annoying as fuck. Imagine diving into a corner. You're full throttle, bam, hit the breaks, then as you are coming through the apex at part throttle the car bucks and falls on it's face, then plants all of it's power back to the ground, and so on. As you get through the corner you pin the throttle and all is well.
Now imagine driving through traffic at 70mph. You are going to dip into the next lane, but you better be careful because there's a car creeping up and you need to get in very gently, but with just a little bit of acceleration. You ease on the throttle, move forward and start to merge. As you are about to get into position and the guy (now mostly behind you) is right on your ass, the car bucks like crazy and then everyone dies.
I'm telling you there has to be a better way! I can't believe there are so many Forge users out there and they are all either accepting of the BS or they're magically not having this problem.
I'm going to try and run the MBC from the LICP and if that doesn't work, I'm going to throw this thing into a grinder.
Last edited by scheides; 10-27-2006 at 10:35 AM.. Reason: mbc from LICP, not the bov, doh!
