Old 11-09-2006   #5
Re: Head Porting Question
Ok so just clean it up and match the runners and gaskets then? What cams should I run with a 6 bolt swap, wisecos, eagles, and a 20g?
You can clean up the casting flaws, but don't gasket match the runners. I wouldn't take the normal Crower springs/retainers to anywhere near 10,000 RPMs. The Crower springs aren't a huge upgrade from stock, but they are cheap. Good for someone looking to rev to 8500 with not too extreme of a came. If you want to rev higher than that or even run a cam with a crazy profile design then you will have to some stronger springs.
