Old 11-15-2006   #2
Re: ECU and Tubo options
Originally Posted by flametail View Post
I haven't seen anything about this so I figure the ECU doesn't have to be adapted or tweaked if you add a larger turbo...but, if i decide to upgrade the turbo, what kind should I get? I don't plan on making an obsurd amount of HP and I would rather it be kinda inexpensive (not cheap). What numbers would I be seeing with different turbos and what are the pros/cons of the different turbos?
Anytime you increase the airflow into our out of a motor you will need additional tuning. Fortunally for this market there are plenty of piggybacks that work very well with most basic turbo upgrades.
There is a huge variety of turbo's you can upgrade to. What is your goal with the vehicle?
