Old 11-21-2006   #6
Re: 1g hesitates at wot higher rpm
As mentioned above: plugs, wires, base timing/idle set, boost leak check, fuel filter, check front balance shaft belt(if the motor makes a buzzing noise about 3500-4000rpm) Timing belt/water pump job if you do not know when it was done, and a clutch would help also. The list could go on, welcome to dsms.
