Old 01-10-2007   #5
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: Boost Control
I changed the hot side from a turbo that had no problem, it has a 2G O2 housing, the actuator opens at 11psi all the way while doing a boost leak test. If it is just creep what do you suggest for a fix? The wastegate flapper is ported some and I ground some of the back in order to let the flap open further.
Do you have any cheap turbos laying around I can pick up?
Thanks for the help
