Old 01-29-2007   #8
Re: Tearing apart the tranny...
Did you remove the two gears off the end of the trans? (36mm nut).
Unless you trans looks like that, you will not get the mid-casing off.
That pic has the 2 gears off, the 5th gear assembly, 5th gear shift fork, detent balls for the shift rails all removed.
Yeah i didnt take the two 5th gears off because i didnt know if it needed to be off. I got the 5th gear shift fork out though.
On that 36mm bolt it has two notches where it looks like they pound it in so that it doesnt move. do i just take a screw driver and bend the notches out again?
