Old 02-19-2007   #3
EclipseGST
EclipseGST's Avatar
Drives: Short Bus
Re: Front Cover Removal (2g)
A lot of timing gears I've taken off, just slid right off... But if you need to use a puller to get it off, you can just make one with a piece of 1/4" flat steel, drill a couple holes in it and bolt it to the pully with the sprocket nut on, then back out the sprocket nut and it should pull it right off.
Other than that, nothing special needed. The balance shafts will come out with the case cover, so no need to unbolt them either.
Originally Posted by shoutbox
