Old 03-01-2007   #11
HiImBrian
HiImBrian's Avatar
Drives: the girls crazy
Re: car problem
No, fuel cut is the ECU shutting off the fuel injectors, this happens when the mas airflow sensor reads to many Hz(to much air). Check for: Boost leaks, fuel pressure/flow problems, base timing, plug wires, coil packs, transistor pack, injectors failing, fouled plugs, that is where I would start looking.
Thats pretty much what I said but in more newbish terms. The engine doesn't get enough fuel because the mas reads too much air. Not tryin to argue or anything, because I'm sure you understand the topic at hand more in depth than myself.
pics or gtfo
