Old 03-07-2007   #12
Pimpin Dsmstyle
Br0k3N
Pimpin Dsmstyle's Avatar
Re: Crazy oil pressure
Originally Posted by Mr.98GSX View Post
The turbo doesnt cause you to creep. That would be fixed with a external waste gate or with a better o2 housing.
heh.. if you read closer, I never said the turbo was causing the creep. I said it was creepING.
The o2 housing I have is godlike. It just so happens that it's a 3inch SS o2elim down pipe on a 14b that was junk to begin with. Last time I checked, people don't generally externally gate 14b's :P
There is a full free flowing 3inch exhaust system with a 3 inch o2 elim on the car. It's obviously going to creep on an iddy bitty turbo like I have.
The question at hand is why does my oil pressure suck? The answer is yet to be known but the next step would be to get an accurate oil pressure gauge setup.
Turbo seals that are on their way out the door ( close to not working, but still good enough to work.. if you get my drift) can cause you to get lower than normal oil pressure correct?
- Josh L.P.
