Old 03-07-2007   #3
Re: What injectors are you running?
What size turbo are you going to run, and on what size motor (stock, stroker, etc?). Also, what fuel do you plan to run on?
I've always gone for the standard 650cc injectors but I've only run 20G turbos and pump gas. If you're going to run anything bigger, high boost, or E85 I'd suggest bigger injectors. I'm currently maxed out on my stock 560's on my evo. I'll probably upgrade to 880's in case I decide to run E85.
