Old 03-14-2007   #16
perryg114
Re: Oil in Intake how much is normal?
Originally Posted by bluntedelvis View Post
Kind've sounds like alot of work do a rebuild on a turbo "a 14b none the less", how much for this do it yourself kit, sounds like when your said and done with all the Balancing and direct placement of parts you would've spent more money than just finding a good "NEW or USED" t-25, 14b, or even a Evo3 without breaking the bank and doing the install yourself.
The bearing kit is $70 and I don't plan on rebalancing. A balance job is around $60 if you do all the work. If send them the center section the rebuild is $250. Here is a good article on rebuilding a turbo. I think getting the thing out of the car is worse than the rebuilding process.
http://www.2gnt.com/www/corbin/rebuild16g.html
Perry
perryg114 is offline   Reply With Quote
