Old 02-12-2004   #7
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
What happens when you overrun your fuel pressure regulator? Would you just run more base fuel pressure?
Could I go walbro 255 high pressure, get a bm regulator and turn the fuel pressure up? Higher fuel pressure would let me lean out the injector signal signal more. See any problems with this?
Setup is currently boost gauge, mbc, upper ic pipe w/ blitz bov, supra mkiv ic, and SAFC. I am wiating to put on my 14b and plan on getting 550's. Will the added fuel pressure be too much for this setup?
7/25/09
