Old 04-11-2007   #28
v8klla
v8klla's Avatar
Re: best head gasket for 91 tsi
Copper normally shouldn't be used unless you are doing an O-ring/reciever groove setup on the block/head. People have had nothing but problems with copper headgaskets the last 10 years on DSMs. Maybe these new ones are better, but the older SCE stuff was crap.
Stock headgaskets are awesome, I run 28psi on stock headbolts with them on my own cars. The Mitsu metal HGs are awesome until they start leaking between the layers. Cometics are great also when the surfaces are prepped properly. There is a reason why they stopped making the Cometic HP versions also.
I agree without the ICS (Internal Combustion Seal) the SCE wouldn't be a viable option. It is as close to O-ringing as you can get without actually doing to machine work lol. And as far as I know the Cometic HP's were discontinued based upon their version of the ICS which moved around freely and caused several issues when not properly installed...
Stock head bolts huh?
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
v8klla is offline
