Old 05-03-2007   #3
Re: is 5 deg BTDC ok?
All the guys on the dsmlink forums said that timing should be set at 10 degrees btdc, so that is what i set it at.
I should just change this topic to "Car wont start"
With the timing at 5 degrees BTDC the car is getting spark out of all plugs.
All of my dsmlink settings are correct.
I am getting fuel pressure to the rail, but i dont know how to check if the injectors are firing. The reason i am even considering this as a possiblity is that the injector electrical plugs are worn, Im going to replace them tomorrow. When i say worn, the plugs look like shit, and the wires are exposed.
The car keeps turning but wont fire up. The timing was off a lot before i did the timing belt this time, but now its dead on and still not firing.
