Old 05-07-2007   #2
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: Clutch to the Floor
Originally Posted by Project2G View Post
So I picked up a 97 Eclipse gst 5 speed with 95xxx miles a month ago from a used dealership in San Diego, and now I'm having a clutch issue. Almost 7 out of 10 times when I shift into reverse it grind (clutch issue not tranny) because it's almost like the clutch is not pushed in all the way even though I push the clutch to the floor. Yesterday and today when I was driving and puched in the clutch the pedal just stayed to the floor?? I had to pick it up with my hand then everything was fine. Both times this happened I was pulling to a parking lot and I'm just affraid it's going to happen why I'm driving dow the road or something. I bleed the clutch yesterday thinking I had air in the lines and the fluid was almost black.. Like they never changed the fluid before. =( Someone told me it's probably the Pressure plate. There is some play in the shift fork. I have also heard when the clutch pedal sticks to the floor when turning it could be crankwalk?? Any imput would be great thanks.
Which way do you turn when it sticks? Mine use to do it, untill I adjusted my pedal all the way out. I later found out my clutch master cylinder is shot.
