Old 06-18-2007   #11
Re: wish i had a 3kvr4 :(
Originally Posted by Mr.98GSX View Post
Then I've got a boost leak somewhere I'm hoping. We tried to do a boost leak test today, but the inlet on the 50 trim is 3inches and the rubber piece I bought when making my boost leak tester is 3.5 inches and I can't tighten it enough to stay on there past 5psi.
Well, make the flat part smaller, get a reducer coupler or something, because if you do the calculation (easy) you'd find that at 5 psi, it's like a 48 lb weight pushing that 3.5" flat surface out of the coupler.
Anyway, you probably don't need more than 5 psi to check for leaks anyway. Just listen and look.
