Old 06-21-2007   #11
joem
Drives: 1991 Talon awd auto
Re: Drilling thermostat
Water actually cools much better than anti-freeze. Anti-freeze is basically to keep the coolant in your block from feezing durring the winter anc cracking your block and sheit. Pressure test the system, and go from there. and yes, jello shots FTMFT
People need to post true. Anti-freeze lubes the water pump stops rust and corrosion in the cooling system rises to boiling point and no freezing in the winter. To much anti freeze in the system is bad lowers the boiling point and will gel in the winter. So unless you know what your talking about dont post.
