Old 06-26-2007   #23
Re: removing the awd system from tranny
Wow.
Transfer case is held on by 5 bolts. That might need some coaxing to get it off the output shaft. Then make sure to support the center driveshaft.
On the front passanger side axle
It would be best to pry alongside the axle/transmission meeting point UNDER the car as there is a bit more room for a pry-bar/even application. A quick "pop" motion should dislodge the axle from the transmission.
Good luck.
