Old 06-27-2007   #24
Re: removing the awd system from tranny
Jeez, newbs helping newbs. No, you don't have to separate the axles from the hubs, just undo the 2 bolts between the strut and the hub. Niterydyr is right for the T-case and you also need to get the DP out of the way, the t-case sits right beside it. There are also 2 bolts holding the intermediate shaft on (drivers side axle) if you haven't found them yet, 14mm.
