Old 06-29-2007   #17
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Re: Anyone ever dealt with oldsmobile?
Originally Posted by 92EvilTalon View Post
So what are the signs for a bad Intake Gasket I may ask? I don't want to replace it if its not bad. Granted the Grand Am has over 165k miles on it.... And also the oil gauge fluctuates.... And the Check Oil light comes on. I do and its full...hot and cold. *sighs*
Symptoms are:
You have a 3100 or 3400 V6
Low coolant, some cars are equipped with a low coolant sensor
Car temp fluctuates or overheats
You can smell coolant at stoplights or after you get out of the car
Coolant leaks under car but not from radiator area
Best thing is to check the ends of the lower intake manifold with a flashlight to see if coolant has leaked and puddled up on the engine block. Mine was leaking on the side where the crossover exhaust pipe is located.
article about manifold leaks http://www.autoblog.com/2006/04/15/g...se-by-case-ba/
online petition for GM recall http://www.petitiononline.com/GMcnsmrs/petition.html
