Old 07-25-2007   #1
Re: Compression
I would do a leak down test to see where your compression is going, valve seats, rings, head gasket. Does the car run funny? why did you do a compression test?
Old 07-25-2007   #2
Bunta
Bunta's Avatar
Re: Compression
Well I'm assuming the reason why the car wasn't running right was because it wasn't tuned and it needed a FMIC.
So I called up my buddie so we can change some spark plugs on it. Than we decided since the spark plugs were off we miles well do a compression test.
The car kind of feels like when one of your injectors go bad and your car just kind of lags for a while than later on everything starts to kick back in inconsistently. You can here the car spool and everything but the car just has the feeling where it's just not getting enough of something.
As of right now I'm going to just get the fmic put on and then get a new head gasket in there and then get it tuned. Hopefully that solves it.
"What you just said was the most idiotic thing i've ever heard, everyone in this room is now stupider for hearing what you just said."
Bunta is offline   Reply With Quote
