Old 07-25-2007   #15
DWs97GST
Re: Compression
First off the numbers being that low ALL the way across probably means ur tester is off a little. BUT it doesnt make a diffrence because you have to much of a diffrence between compression therefore there is a problem somewhere. I would suggest a rebuild. NOW if it kinda takes off slow and gradually get better it could be because as u go you build compression. If one of your cyl is not sparking because the compression is too low then once it build up a little from moving then you will get spark and gain that cyl back.
DWs97GST is offline   Reply With Quote
