Old 08-06-2007   #3
Enes
Enes's Avatar
Re: GST to GSX Fuel Sending Unit Wiring
# On the AWD Passenger Side Fuel Pump/Sender Connector
1. Thick blue/black wire is fuel pump power and is connected to the same wire on the 2 pin FWD fuel pump harness
2. Thick black wire is the fuel pump ground and is connected to the same wire on the 2 pin FWD fuel pump harness
3. Thin yellow/black wire is the sender feed to the second sender and is wired into the yellow/black coming from the other sender
4. Thin black wire is the sender ground and is wired into the ground wire on the FWD 3 pin sender harness
5. Thin yellow wire is the low gas light wire and is wired into the non-yellow wire on the FWD 3 pin sender harness
# On the AWD Driver Side Sender Connector
1. Thin yellow/black wire is connected to the yellow black wire coming from the passenger side sender
2. Thin yellow wire goes to the fuel gauge and is connected to the yellow wire in the FWD 3 pin sender harness
