Old 08-09-2007   #9
Re: PCV System
That crankcase breather port isnt suppossed to be open to atmosphere. From the factory that port is routed into the piping in front of the turbo which assures a constant vacuum.
The problem is most DSM's are running around with them not hooked up to the intake, and also regular PCV valves leak boost through into the crankcase.
$110 for these things isn't exactly cheap, but at the same time they are serving a lot of functions. For the dip stick popping out its an actual solution, not just a patch like zip ties or springs to hold it in. I am glad I bought mine, I plan to get them for any car that I modify and consider to be my "good car".
