Old 02-24-2004   #1
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
The car is a 2G AWD with an ACT 2600 with about 5000 miles on the clutch
Lately, ever since it started getting cold, my clutch has been acting really wierd. In the fall, I re-adjusted my clutch because the engagement was getting kinda low but now it is acting totally different. I dont know if it is because it isnt adjusted right or of it is because of the cold weather. When it is cold, there is almost no pedal pressure except towards the bottom of the pedal travel. If I pump the pedal a few times, there is enough pressure to disengage the clutch all the way and get into gear normally. After the car has warmed up for about 20 minutes, the pedal is totally normal and you could not even tell there was a problem. The fluid level is normal so I dont think there is a leak. What do you guys think it could be?
Thanks
tsiawdspeed is offline   Reply With Quote
