Old 08-10-2007   #27
Re: PCV System
I would be highly surprised if the Kranks vents do anything else more than seal off the boost from the intake manifold. Our cars have metal PCV valves, at least my 2g does. No Krank valve on my car, the system works as it's supposed to, and I've never had a dipstick pop out. So maybe I'm just not seeing the miracle cure you guys are seeing. As long as you can relieve the crankcase pressure under WOT boost conditions, the stock PCV will work fine under normal driving condiions. That's all I'm saying.
