Old 08-20-2007   #10
Re: Oil pressure guage question...
You can run a 1/8" NPT tap down the 1/8" BSP hole and the sensor will thread in, or use a reducer off the allen plug that sticks straight out off the oil filter housing, and if you want to plum oil to your turbo use the hole that points down at an angle, VFAQ goes over this. Heat and liquid wrench or similar will help, but if you strip it out they are not that hard to remove, off the car that is.
