Old 08-22-2007   #15
Re: No start
You say that you have fuel and you have spark and you have compression. Those are the 3 essential things your need, but if your a/f ratio is way off (due to say a bad coolant temp sensor) then it won't start. You said you can hook up your logger, can you check what your temp sensor is reading? those little bastards can go bad and cause a no start condition.
