Old 08-28-2007   #8
gofastman
James Bond... James Bond
gofastman's Avatar
Drives: 95 Jeep
Send a message via AIM to gofastman
Re: Rings bad?
I am going to try that. Ill use a straw and try and get the oil to the edges of the pistons.
use heavy oil if posible, like a 40 weight.
if you do replace the rings you probably could leave it in the car if you want to flat rate it, and it would probably work too, but if you want to do it corectly I would pull the motor so you can thourghly clean it with a pressure washer and hot soapy water
-David C.
Originally Posted by bouncer07
If you know Mary Clifford, Ph,.D. Associate Professor of Criminal Justice in St. Cloud State University. Then your well aware of who she is.
gofastman is offline   Reply With Quote
