Old 09-22-2007   #1
2.SlowES
2.SlowES's Avatar
Re: Which Oil to use on a freshly rebuilt motor?
Do you really need to change it as often as Ecoli said?
I'm about to start mine for the first time since the rebuild too. Also, by three starts, do you mean you just started it and let it run? Or went and cruised around for a bit? How long untill it's fine to start boosting?
2.SlowES is offline   Reply With Quote
Old 09-22-2007   #2
Yes. I follow a similar routine when breaking in new motors.
Old 09-23-2007   #3
2.SlowES
2.SlowES's Avatar
Awesome, thanks guys! And sorry for impeding on your thread...
Old 09-23-2007   #4
eclipse_spyder
The most ricest dsm
It's a good thing you brought that up cause I didn't know that either.
eclipse_spyder is offline   Reply With Quote
Old 09-25-2007   #5
Dsmboy1991
There are quite a few different theories on break in. However I agree with Jet with the frequent oil change method. The luck I had with mine was using a heavier weight 20w 50. I changed, after first day of running, 500, 1000, 1500, then switched to 10w 30 synthetic and regular routine. Like I said though, alot of different theories are out there, ha ha.
Dsmboy1991 is offline   Reply With Quote
Old 10-08-2007   #6
badinblack
badinblack's Avatar
Drives: 96 talon, 2.4L & 3582r
For brand on break in, I have always used rotela 10w30. The properties in it are great for break in. I am suprised no one else has mentioned it yet here.
badinblack is offline   Reply With Quote
