Old 10-18-2007   #1
turboDSM
turboDSM's Avatar
Drives: tastefully modded BMW : )
**NEED HELP!! IT wont start AGAIN!**
Hey all, Well heres the story. Im jammin to a buddies house last night and the car just dies as im driving, and wont start back up. The car has spark and is getting fuel to the rail, But, the injectors are not pulsating. The main MPI and ING fuses are good.
What do you think? ECU caps? Some relay I cant think of?
turboDSM is offline   Reply With Quote
Old 10-18-2007   #2
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: **NEED HELP!! IT wont start AGAIN!**
Take out the ecu and look at the caps if their leaking that could possibly be your problem. Leaky caps can cause alot of different things. on another note how do you know for sure your injectors are not spraying? and if thats the case then it could be a bad injector? Also even though you have fuel at the rail, do you have enough fuel pressure? you need to do some testing..
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
Old 10-18-2007   #3
Did you check the timing belt?
Old 10-19-2007   #4
dragonforce
Squirt some starting fluid.
Old 10-21-2007   #5
turboDSM
turboDSM's Avatar
Thanks to all! it was the ECU caps..all fixed!
