Old 12-03-2007   #11
Re: whats up
+1 (again woot JET), you should be able to turn your boost up to, say 16psi, and then it will rise up to 19psi by redline from the boost creep. You should then also be able to set your boost at 19psi, and it will not rise much if any by redline. If this is not the case, something else might be amiss...weird MBC or something?
I love the LIPP housing that LSE sells, it is awesome and I highly recommend it. On the same note, might be $$ more well spent on porting and DSMLink, so you can run E85 next summer
