Old 12-13-2007   #1
GsXtUrBo98
GsXtUrBo98's Avatar
Drives: 98 GSX, 04 is300
Re: 95 talon awd
I would make sure both are tight.
Try this old mechanic trick. Get some belt dressing and put a little on one belt and see if it goes away. If not try the other belt.
In my experience if a belt was making noise, it was always the alternator belt. Could be a sign of a failing alternator also. Had that happen also.
Ok so all i have to do is try tightening the screw/bolt for the alternator and see if it stops squealing or not. Then if it does try the belt dressing??
Ok but what if i do the belt dressing and find out that its the alternator and its tight?? do i get it tested to see if its bad? or what
Old 12-13-2007   #2
Re: 95 talon awd
Then it would likely be a bad belt, it could have oil on it. That usually goes away though. Might just be a crappy belt that gets hard in the cold. It probably just isn't tight enough.
Old 12-13-2007   #3
GsXtUrBo98
GsXtUrBo98's Avatar
Re: 95 talon awd
Ok ill check it tomorrow.. Its so fuckin cold out that I dont wanna fix it cuz no room in the garage now cuz thats where the GSX goes!!! lol
So i tighten it with that bolt right????
Old 12-13-2007   #4
blageo23
AWD4G64
blageo23's Avatar
Re: 95 talon awd
First you loosen the bolt that connects to the alternator, then you tighten the tensioner bolt.
Old 12-13-2007   #5
Re: 95 talon awd
Yep, 12mm, goes the normal clockwise direction. You will likely have to push the bolt down once in a while, it likes to ride up. If it pops out, then you get to loosen it back up and start all over again.
Old 12-13-2007   #6
GsXtUrBo98
GsXtUrBo98's Avatar
Re: 95 talon awd
Wow that one sounds like fun!!!! not! but i never really is when it has something to do with maintainance, but upgrading is a different story lol.
Old 12-13-2007   #7
blageo23
AWD4G64
blageo23's Avatar
Re: 95 talon awd
A ratchet wrench is your friend when it comes to tightening the ALT belt
Old 12-13-2007   #8
Re: 95 talon awd
Yeah, that or a flex head ratchet. It is really quite easy though.
Old 12-13-2007   #9
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Re: 95 talon awd
I did a V-8 swap into a Astro van, belts squealed like crazy but they were tight. Dad hands me a bar of soap and says start it and let it run on the belt. Never squealed again.
Old 12-13-2007   #10
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: 95 talon awd
Depending on the last time you changed the belts, it maybe worth just replacing both when you go to the autoparts store. That way you know you have good belt for the winter and wont have to mess with them for a while.
Old 12-13-2007   #11
GsXtUrBo98
GsXtUrBo98's Avatar
Re: 95 talon awd
just replaced ALL the belts less then a month ago...
So i sould put a bar of soap under the belts as its running?????
Obviously if tightening the alt. belt doesnt work i mean???
Old 12-13-2007   #12
Andrew7dg
Andrew7dg's Avatar
Re: 95 talon awd
Well that might solve it for a little bit but using a bar of soap everytime the car squeels seems kind of dumb to me.
On a date,
"Excuse me for a minute, my cars belts are squeeling. Do you have a bar of soap I can use?"
Just use the soap technique as a tool (same as belt dressing, doesn't matter which one you use)
After checking to see if both belts are tightened
Apply it to one belt, if it doesn't stop
apply to second belt
If the squeeling stops on the belt, you know which one is giving you problems.
If it doesn't stop, replace belts and see if that stops it
How long have they been squeeling? You could have burned through one by now. still don't rule out the alternator.
Old 12-13-2007   #13
AwdGSX13
AwdGSX13's Avatar
Drives: Cars
Re: 95 talon awd
My alternator belt was giving me the same bs just the other day, although when i tightened mine down i had the same problem. It wouldnt stay tight. Since mine doesnt have the adjustment screw all i did was put a washer in between the two tension pts on the front of the alternator that the bolt goes through. Havnt had a problem since.
Dont tighten it too tight, ive had one snap on me because of it being too tight. And if the belt is squeeling, chances are that the components are fine its just the belt. Soap works very good as dressing, same with wax pens.
-Matt
'94 Eagle Talon TSI AWD
'06 Acura TL
